I have around $600 for a new GPU and I don't know which one to choose, I was thinking to get an RTX 2070 Super, but I don't know which brand or if there is a better option for a similar price.
I'm currently using an RX 480 and my monitor is 1080p, but I want a card that can run smoothly 1440p and maybe a little bit of 4k because I'll probably be getting a new monitor soon enough. My case has a lot of space so getting a big card is no issue.
My specs are:
Ryzen 5 2600x
16GB DDR4 @3200 Mhz
Evga 750
https://linustechtips.com/topic/1151077-need-help-choosing-new-gpu/
Besides waiting and hoping for big Navi there is no other option. With 600$ you're able to afford a top of the line 2070super.
About the other cards: 2080 is maybe a bargain used but not really available anymore and 2070s is faster sometimes. ti is to expensive.
Idd go with a EVGA SC Ultra, ASUS strix (at some places it can be found for about 600) or maybe Zotac super amp.
Personally I will wait for AMDs big navi but I am a AMD fan :D. Nvidia wise idd go with Asus if under 600, else with EVGA. But thats personal taste and either of those performs relatively close to each other
FOLDING MONTH 2021! GOGOGO and save on some heating costs 🙂
1 minute ago, Shimejii said:
Honestly? You could get a Used 2080 Super on Ebay right now for around 600$
Daaaaang! Well not in my country for this prices.
If getting used OP should still look for a nice cooler.
Yeah Ive seen quite a few of the EVGA 2080 Super cards for 600 USD atm on ebay :)
Alright, thanks.
3 minutes ago, Neftex said:
wait for summer to make decision if you can, we should be getting new generation of rtx that actually could be usable this time
+hopefully a powerful navi...
Can't say I understand the love for going used in this price range. I mean if you have $80 to spend and it's between buying a crap GT 1030 or a used RX 570 then I fully understand going with the used 570 that will actually give you a pretty good gaming experience vs the 1030 that's just going to suck and feel like you're playing an XBox 360 in 2020. But paying $600 for a used 2080 Super when it's only 14% faster at 1440p than a 2070 Super you could buy brand new for $500? That's lunacy to me. You don't know if maybe that 2080 Super is a card bought refurbished. Or a card that has been ridden really hard. Or a card with a defect that might make it fail before your have it for three years. If I'm spending that much I want a warranty, I want to know that card is going to provide me with three good years of gaming. If I buy a brand new 2070 Super I can be pretty confident in that.
Yeha I guess that is personal preference. I had a 2x290x CF for some time and both were used mining cards. Dirt cheap but fast.Ok and toasty and power hungry as hell :D
Had no failure. Used em 24/7 full thrust for F@H. Also my VII that I have now is also a used unit and also on 24/7 100% for about half of year now.
My specs are:
Ryzen 5 2600x
16GB DDR4 @3200 Mhz
Evga 750
i'd wait, but if you can't wait, rtx 2060 new for 300usd, 5600xt for the same price~, any of the 2060S and higher cards need to be on sale to be in consideration.
recently saw a 2070S for 425usd.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
Where was that? Damn that's a deal.
it was some temp price drop on newegg, there was also the 2080 ti strix for 989
My specs are:
Ryzen 5 2600x
16GB DDR4 @3200 Mhz
Evga 750
2070 super is the best choice
