Define “fast” eBay is your best bet.
https://linustechtips.com/topic/1150419-help/#findComment-13256641
1 hour ago, Rennanways said:
is there anyone that can help me find a fast pc under 220 dollars
Basically what everyone above me said. For 220 bucks, you won't get a hell of a lot.
That said, I have sold an older i5, Radeon 7770 GPU and like 4 GB of RAM for ~150 bucks, so you can find deals like that on craigs list and ebay etc. But thats just sorta luck of the draw. I sell used PC parts for relatively cheap, I want them gone and to live in outside a landfill, and I don't feel like ripping off the person buying them. I have sold working PC's with 3-4th gen i3's and 4 GB of RAM for ~70 bucks. Not exactly a lot of PC, but pop an SSD in it and its a TOTALLY viable little machine.
https://linustechtips.com/topic/1150419-help/#findComment-13256696
Fast at what
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1150419-help/#findComment-13259311
Please do not make duplicate threads -- threads merged and moved to New Builds and Planning.
Please read:
https://linustechtips.com/topic/1150419-help/#findComment-13259319
