Currently i have a team group elite tuf edition running with xmp timings at 3200mhz cl 16. It was originally a 3000mhz cl16.  I tried to do the memory tuning using the tuning software. But i cant seem to get a stable oc anything above 3200mhz cl16. Is it just bad  silicon or am i doing something wrong?
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1150111-micron-e-die-overclocking-help/
 Nothing wrong, just a bit of a bad silicon
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
51 minutes ago, WereCat said:
what voltage? which cpu and motherboard?
1.36v, ryzen 5 3600 , MSI B350m Bazooka . It was quite old. I just upgraded the ram so im kinda having troubles with it.
CURRENT PC SPECS
Need more voltage and further loosening of tRP and tRCD most likely, but dont be surprised if that doesn't go much further. After all there's a reason why higher rated kits cost more.
Desktop benching:
are you sure it's micron-E die? not micron-D?
HWluxx forum has a load of micron-E settings-timings shared in the appropriate thread. See this:
https://www.hardwareluxx.de/community/threads/micron-8gbit-e-die-ddr4.1233479/
suggest browsing through the shared pictures, even later posts. .. Are your RAMs in the right slots?
Life is really challenging. I don't always suceed: )
yes. im sure it was micron e die due to the typhon thing.
I cant read German yet :(
Edited by Martin2132
CURRENT PC SPECS
which is sometimes wrong
Desktop benching:
then, is there any way to find out what kind of die it is? The packaging doesnt say anything about it so im not sure.
CURRENT PC SPECS
google translate works like magic when it comes to related tongues. Will make understanding the thread effortless. :) and the screenshots do not even require it..
dont need to know tbh, while the max frequency and timings for that frequency is different, anything but B-die follow the same rule that everything goes loose rather quickly, other than tCL.
Desktop benching:
