No it wont, none of the AMD/Intel coolers block RAM. They dont even go above RAM.
Desktop benching:
Seems close. https://pcpartpicker.com/b/z8LJ7P
I'd recommend going with cheaper and lower profile ram like an Aegis kit for better compatibility with future components: https://pcpartpicker.com/product/mcH8TW/gskill-aegis-16-gb-2-x-8-gb-ddr4-3200-memory-f4-3200c16d-16gis
Good thinking, think I might go with that instead. Thanks for the help
59 minutes ago, Jeppes said:
Thank you, may consider going for better cooling then the aesthetic I was going for.
