Friend needs my help
Go to solution Solved by Xiee,
That seems okay, but the case might be unnecessarily overkill since it's usually for liquid cooled systems. Might want to go with something like a Meshify and add some good fans on the front.
Here's my take on your build:
So my friend comes to me with this build (linked below) and asked me it this is a good build for a beginner and if it was good for the price point. So what do you guys think, I think it's fine.
https://www.microcenter.com/site/content/custom-pc-builder.aspx?load=861c749d-261c-4d59-a211-037272c14385
https://linustechtips.com/topic/1150028-friend-needs-my-help/
The deep blue sky is infinitely high and crystal clear.
私はオタクではありません。
https://linustechtips.com/topic/1150028-friend-needs-my-help/#findComment-13253850
4 hours ago, boggy77 said:
why?
i'd get a corsair txm instead
Meh, superior build in every possible way..
PSU can be upgraded to a better unit for $20 more.
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($179.99 @ Best Buy)
Motherboard: MSI B450M PRO-VDH MAX Micro ATX AM4 Motherboard  ($79.98 @ Amazon)
Memory: G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3200 Memory  ($64.99 @ Newegg)
Storage: Silicon Power A80 512 GB M.2-2280 NVME Solid State Drive  ($69.98 @ Amazon)
Video Card: XFX Radeon RX 5700 XT 8 GB THICC III Ultra Video Card  ($389.99 @ B&H)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  ($44.99 @ Amazon)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($59.99 @ Corsair)
Total: $889.91
Generated by PCPartPicker 2020-01-29 09:55 EST-0500
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1150028-friend-needs-my-help/#findComment-13254825
8 hours ago, Xiee said:
Oops I missed that. Thanks for catching it.
Total: $889.91
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1150028-friend-needs-my-help/#findComment-13256580
