Hello my name is chris I have a problem when I boot up my pc with my graphics card the white led stays on and It takes a bit to boot up that way but when i remove my graphics card it boots up fine
I have a asus z390 e gaming rog motherboard with a rtx 2070 and 16gb hyperx ddr4 memory I have never had this problem before please help
https://linustechtips.com/topic/1149888-problem/
Did you connect your display to GPU or MoBo? If MoBo, then reconnect to your GPU.
Purify your Windows 10/11, don't give Microsoft anything that you don't want to share.
https://drive.google.com/open?id=1ZwVs9zrM493rjD42E2Pf0YcOkaW92ZUo
Tips for folding on laptop:
Lazy man wants upgrades from the sky.
https://stats.foldingathome.org/donor/Spakes
https://linustechtips.com/topic/1149888-problem/#findComment-13252129
3 hours ago, hexdragen4 said:
I have done both way to check I have put hdmi cable in the gpu and to the motherboard?
What display signal do you use for you GPU not the igpu the 2070
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1149888-problem/#findComment-13252632
