My Rig-
CPU- AMD FX 8120
RAM- Corsair Vengeance 4x2 GB
HDD- Seagate barracuda 2 TB
GPU- Sapphire Vapor-X R9 290
Mobo- ASUS 970 PRO GAMING/AURA
PSU- Corsair TX 750M
Hi guys,
                  Don't know why my CPU fan acting weird from past few days, CPU fan only start when processor temp. goes above 50C with 100% rpm and below 50C back to 0% rpm and i think going 0% rpm not a good thing. I tried everything like cleaning CPU fan and vents, checked CPU fan header, reapplied thermal paste, default BIOS, uninstalled Asus AI suit consist Asus Fan Xpert and updated BIOS. I am using ThermalTake Contac 9 Air Cooler. Here's the video link for better understanding: https://drive.google.com/file/d/10qlN5_vQOd3yBhYehaiFBkJU60Tlhm6Y/view?usp=sharing
https://linustechtips.com/topic/1149857-cpu-fan-failed-error/
Fan broken?
Or does it have the 4pole connection is that connected correctly?
Else goto begin
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
https://linustechtips.com/topic/1149857-cpu-fan-failed-error/#findComment-13251764
4 hours ago, M4DH4WK said:
same as shown in provided video link
You could try to plug the CPU cooler fan on another header on the motherboard and see if you have the same issue. If you do, it could be an issue with the fan at low rpm, changing the fan should fix the issue. If it works fine, then it's an issue with the CPU fan header on the motherboard.
https://linustechtips.com/topic/1149857-cpu-fan-failed-error/#findComment-13252646
