I can't in my right mind recommend any phone for gaming...
According to reviews it can reach 43 degrees Celsius on the outside(parts you touch) under load without throttling...
Refresh rate can be 60 or 90 Hz, I believe 60 should be easier for phone to handle.
Software allows to disable notifications and 2nd SIM card, so all the device does is running the game...
https://linustechtips.com/topic/1149827-one-plus-7t-help/#findComment-13251523
