Hello, I just recently built my first computer and was wondering if overclocking it would really give me that much more performance.
Specs: CPU 3900x, Deepcool Assassin III CPU cooler, GPU RTX EVGA 2080 Ti FTW3 Ultra, MB Gigabyte X570 Aorus Xtreme, Gskill Trident Neo 3600MHz 64GB @ 16-19-19-39, & Sabrent Rocket 4 NVMe PCIE M.2 2x1TB 1x2TB.
Current Cinebench score is 7079.
UserBenchMark 146% Gaming, 170% Desktop&Workstation.
Not sure Userbenchmark gives me different m.2 drive result than CrystalDiskMark7. Crystal says they're running at 5009.58 Read and 4281.32 Write the slowest was 4890.78 Read and 4281.58 Write.
I also noticed my Gskill Ram is only at clocked @ 2133 MHz but I would think it should at a minimum be getting 3600 MHz. Was there a BIOS setting I missed?
Any suggestions on the best way to get my PC running at its full potential would be great or at least getting the Ram running where it should be.
Gigabyte GA-X570 AORUS XTREME Performance Results - UserBenchmark - Google Chrome 1_27_2020 6_19_49 PM.png
Gigabyte GA-X570 AORUS XTREME Performance Results - UserBenchmark - Google Chrome 1_27_2020 6_20_14 PM.png
Gigabyte GA-X570 AORUS XTREME Performance Results - UserBenchmark - Google Chrome 1_27_2020 6_21_02 PM.png
Gigabyte GA-X570 AORUS XTREME Performance Results - UserBenchmark - Google Chrome 1_27_2020 6_21_40 PM.png
https://linustechtips.com/topic/1149747-max-performanceoverclocking-tips/
What resolution you playing at? This system is really great, imo you not gonna gain much more performance, so to answer the question, of you happy with the performance you getting now, don’t oc. If you not happy just go for it and test it yourself.
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
