do you mean that the third pin out 4 is missing? fan splitter cables always leave out the PWM pin on the second header (either not connected, or physically missing) because it is a signal that is produced by the fan, and combining the output of two fans may have "unknown" results.
https://linustechtips.com/topic/1149673-fan-control/#findComment-13250393
The 3rd pin is the for rpm and not pwm. The 4th pin is for pwm which can still be used for control / modulating the signal. The rpm is only read from one fan.
https://linustechtips.com/topic/1149673-fan-control/#findComment-13253182
thats what i meant, i must've been tried the other day.. ?
https://linustechtips.com/topic/1149673-fan-control/#findComment-13253190
