Air cooler for 3800x
Ice cube
Hi guys i want to upgrade my stock cooler to better one and i have these choices
Noctua nhd 15s
Dark rock pro 4
Nhd 15 i don't know if it will fit in my case i have nzxt h500 and i read that it has ram compatibility issues (have the g skill trident z)
So it's between the  15s and pro 4 which one you recommend
Noctua nhd 15s
Dark rock pro 4
Neither has glaring problems. No strong recommendation.
After considering your ram clearance that I think you've answered, according to the specs, you should have about 5mm of space left over with the NH-D15S (160mm) and an H500 (165mm total max) case.
According to various posts on reddit (and here), the Dark Rock Pro 4 (163mm) does actually fit in an H500 (165mm total max) with a bit tighter of a fit at 2mm left to spare. Not sure about ram without searching more. They included pics of it installed in their case: Imgur Photos of Dark Rock Pro 4 in H500 case
One thing that might or might not matter: am4 is rectangular and as a result some am4 attachment brackets force a cooler into up/down configuration.  May not matter even if it happens because both coolers have fans that can handle up/down.  Might possibly matter for plans for your case though.
I know that both fit inside but i saw theses images too and i just don't know which one to pick go for the brand and choose noctua or go for the look and pick the pro 4 they are almost identical in performance
There’s always what’s on sale.
Ah I see. I'm actually considering both of these exact coolers for a 3900X system I started buying parts for. For me, whichever I can get for a better price and availability in my area. The NH-D15 chromax black consistently comes in at being more expensive in my area so...
Either will be a good choice.
Edited by Theorica
Wrong product name
9 minutes ago, Theorica said:
Ah I see. I'm actually considering both of these exact coolers for a 3900X system I started buying parts for. For me, whichever I can get for a better price and availability in my area. The NH-D15S chromax black consistently comes in at being more expensive in my area so...
You mean the nhd 15 is black not the s because if the nhd 15 s was black i will choose it over the pro 4
Well they are at the same price now i'll wait for one to get cheeper than the other and pick it?
Typo. You're right. Took me a moment to figure out what you were saying. Cheers!
There are some internet tools for that.  I’m not super familiar with them only knowing that they exist.
The NH-D15 fits fine. Here's an example: https://pcpartpicker.com/b/XzBbt6
