14 minutes ago, TheGlenlivet said:
If you like the looks of the Matrexx and want a big 'ol eatx capable case then go for it.  It has decent reviews and is in your price range.
Will it be better?  What are you trying to improve?
cleaner look and better wire inside. with  psu shroud should get me that
https://linustechtips.com/topic/1147956-need-a-50-70-case/#findComment-13237144
3 minutes ago, TheGlenlivet said:
Then yeah, that is an upgrade.  With the glass you can RGB to your hearts content.
ill buy 4 fans for 3 in front and 1 in the back if i get that. do i need something to tie all the fans together before connecting them to the PSU or Motherboard(im kinda new to building pcs alone)
https://linustechtips.com/topic/1147956-need-a-50-70-case/#findComment-13237180
For power you can use Y connectors if you run out of headers on the mother board for that many fans.  It's basically the same for the RGB, there will be a header on the motherboard for that too.
https://linustechtips.com/topic/1147956-need-a-50-70-case/#findComment-13237188
