Low frame issue
Specs
760 gma-p34 (fx) motherboard
AMD fx 8320 8 core cpu
16 gigs ddr3
Evga 2060 sc dual fan GPU
600 evga psu
Not sure why but it spikes my cpu and then I have no frames or I crash
Any thoughts I'm lost.
Games I'm playing
Arma 3
Ark survival evolved
Generation zero
Boarderlands (all)
Warframe
Tom clancy's ghost recon wild lands
https://linustechtips.com/topic/1147441-low-frame-issue/
looks like a CPU bottleneck to me
you should upgrade your CPU to solve this
G502 Lightspeed Review
PC:
i5-6400
GIGABYTE GA-H110M-DS2
CORSAIR VENGEANCE LPX 2X4 DDR4-2666MHz
ASUS ROG STRIX-GTX 1060-O6G
SEAGATE 2TB HDD
FUJISTU F300 240GB SSD
CORSAIR CX750M
Laptop:
Acer Nitro 5
i5 8300h
GTX 1050 4Gb
12 Gb RAM
128 Gb SSD
1 Tb HDD
Peripherals:
Keyboard:
Logitech G310 Atlas Dawn (Romer G)
Rexus Legionare MX5.1 (Content Browns)
Mice:
Logitech G602
Logitech G502 Lightspeed
Steelseries Rival 105
Logitech M330
Headset:
Logitech G430
Cooler Master MH 752
https://linustechtips.com/topic/1147441-low-frame-issue/#findComment-13232661
50 minutes ago, Felix ur face said:
Low frame issue
Specs
16 gigs ddr3
600 evga psu
Games I'm playing
Arma 3
Generation zero
Boarderlands (all)
Warframe
Get rid of the FX 8320, despite being 8 cores its single core performance is complete garbage. The motherboard you're using is AM3+ so you will need a new mobo to get Ryzen CPU's. AM4 mobos are usually about $50 to $100, and something like a Ryzen 5 2600 is only $120.
https://linustechtips.com/topic/1147441-low-frame-issue/#findComment-13232709
Any recommendations on a board ?
https://linustechtips.com/topic/1147441-low-frame-issue/#findComment-13233961
Depends what’s your budget. B450 Tomahawk Max is really good choice
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1147441-low-frame-issue/#findComment-13234177
