  • This is my AIDA64 score.
  • On Intel website it says: Max Memory bandwidth (41.6 GB/s) is the maximum rate at which data can be read from or stored into a semiconductor memory by the processor.
  • Does this means that my fast RAM is useless? 8.4 GB/s of waste?
  • Thank you.
https://linustechtips.com/topic/1147422-max-memory-bandwidth/
No, because Intel only lists the maximum bandwidth they officially support. Technically you are overclocking the memory interface.
EDIT: Even if the system were capped to what's listed, you'd see the capped value. The fact that the program can report a higher one is indicative that it's faster.
Edited by Mira Yurizaki
https://linustechtips.com/topic/1147422-max-memory-bandwidth/#findComment-13232469
That number is taken from the officially supported/validated memory speed of 2666MHz. Anything faster than 2666MHz is an overclock usually through a XMP profile.
No.
  • Thank you.
No problem.
https://linustechtips.com/topic/1147422-max-memory-bandwidth/#findComment-13232474
