I know that the ideal remover for thermal paste is high % isypropyl alchohol but I cant seem to find it ANYWHERE in sweden. Are there any alternatives?
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/114727-thermal-paste-removal/
You can use acetone or nailpolish remover. If you are really in need, you can use a strong alcohol, like very strong vodka or rum (make sure that there hasn't been added sugar or other such incredients to the alcohol).
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/114727-thermal-paste-removal/#findComment-1533633
I believe It's called "rengöringsbensin" in Sweden, you can get it in any hardware store.
https://linustechtips.com/topic/114727-thermal-paste-removal/#findComment-1533634
You can use acetone or nailpolish remover. If you are really in need, you can use a strong alcohol, like very strong vodka or rum.
Well I was going to use acetone but people said its way to strong
https://linustechtips.com/topic/114727-thermal-paste-removal/#findComment-1533635
It is not recommend to use, but it does work. You can also use benzine, but that is also very strong.
https://linustechtips.com/topic/114727-thermal-paste-removal/#findComment-1533649
Well I dont want to take any chances but on the other hand, nowhere in sweden sell isopropyl alchohol
https://linustechtips.com/topic/114727-thermal-paste-removal/#findComment-1533662
I just wiped it off with clean paper, and we are still on topic, don't argue otherwise.
Case Bitfenix Ghost, Mobo Asus Maximus VIII Ranger, CPU i7 6700K @4.2 Ghz cooled by Arctic cooling Freezer i30, (barely). GPU Nvidia GTX 970 Gigabyte G1 @1519Mhz core, RAM 16Gb Crucial Ballistix CL16 @2400Mhz. SSD 128GB Sandisk Ultra Plus as my OS drive. HDD's  1TB  Seagate ST31000524AS its OEM, 3TB Seagate Barracuda, 2x 500GB WDC Blue (RAID 0)
If it isn't working absolutely perfectly, according to all your assumptions, it is broken.
https://linustechtips.com/topic/114727-thermal-paste-removal/#findComment-1533664
As far as a bit of googleing has thought me, isopropyl alcohol in Sweden should be called either "Teknisk sprit" or "rent ethanol". I know the laws on alcohol are very strict in Sweden, so I don't know if these things are allowed to be sold for home use.
https://linustechtips.com/topic/114727-thermal-paste-removal/#findComment-1533688
If acetone is being sold, I think this will be sold :P
https://linustechtips.com/topic/114727-thermal-paste-removal/#findComment-1533696
use wodka or something like that
I dont think thats a good idea lol
https://linustechtips.com/topic/114727-thermal-paste-removal/#findComment-1533709
Should I go with acetone or vodka?... and what are the risks?
https://linustechtips.com/topic/114727-thermal-paste-removal/#findComment-1533736
Of the two, you should use acetone. Vodka is not recommend at all, and should only be done if you are out of other options.
The risk of acetone is that it can damage the PCB, though the risk is not that big. Just dampen a piece of paper and rub it on the area that you wish to clean.
https://linustechtips.com/topic/114727-thermal-paste-removal/#findComment-1533754
If I use an ear cleaner tip will my chances be decreased?
https://linustechtips.com/topic/114727-thermal-paste-removal/#findComment-1533771
That would take forever, but I guess the risk would be lowered. The risk of anything happening is very small, so I wouldn't worry about using paper and/or cloth to do it.
https://linustechtips.com/topic/114727-thermal-paste-removal/#findComment-1533785
Some people say that the acetone will dissolve the metal
https://linustechtips.com/topic/114727-thermal-paste-removal/#findComment-1533788
Without going into chemistry to much. No, acetone cannot dissolve metal. Acetone can react with other chemicals that can dissolve metal, but those chemicals are not present in neither the air nor on in a PC. You will also be applying and wipeing the acetone so fast, it won't have time to dissolve anything. Acetone can only really be used for dissolving organic materials. This is why it is used to prep for paint, becuase it dissolvs the oils that is in wood.
https://linustechtips.com/topic/114727-thermal-paste-removal/#findComment-1533819
Without going into chemistry to much. No acetone cannot dissolve metal. Acetone can react with other chemicals that can dissolve metal, but those chemicals are not present in neither the air nor on in a PC. You will also be applying and wipeing the acetone so fast, it won't have time to dissolve anything. Acetone can only really be used for dissolving organic materials. This is why it is used to prep for paint, becuase it dissolvs the oils that is in wood.
I found some acetone nail polish remover lying around. Is that going to work? I can take pictures of the bottle if u want
https://linustechtips.com/topic/114727-thermal-paste-removal/#findComment-1533846
As long as it has a high percentage of acetone in it, and there hasn't been added perfumes or other cosmetic stuff to it, it should work.
I'm not familiar with all brands of nailpolish remover, so taking a picture of the bottle won't help.
https://linustechtips.com/topic/114727-thermal-paste-removal/#findComment-1533861
Yes that is perfectly fine.
https://linustechtips.com/topic/114727-thermal-paste-removal/#findComment-1533868
shit it has added fragrance
https://linustechtips.com/topic/114727-thermal-paste-removal/#findComment-1533873
to bad it has added fragrance :(
https://linustechtips.com/topic/114727-thermal-paste-removal/#findComment-1533875
That doesn't matter...you're not soaking the CPU in it overnight lol.
You sure? What do you think @Volbet ?
https://linustechtips.com/topic/114727-thermal-paste-removal/#findComment-1533893
Make sure you clean it well with a dry piece of paper or a micro fiber cloth afterwards and you should be fine. Fragrance and perfume are not the same thing and I'm sorry I didn't specify that.
https://linustechtips.com/topic/114727-thermal-paste-removal/#findComment-1533894
