First PC Build Help
I wouldn't really recommend a cooler as the stock cooler does a fine job of cooling the chip at stock. The money put towards the cooler can be used to upgrade the CPU to a 3700x.
Also, you won't need a thermal pad. The stock cooler comes applies with thermal paste.
Ryzen loves fast dual channel memory. Added a 16gb 3600mhz cl16 kit.
Added a slightly better SSD for cheap.
Replaced the PSU with a significantly better unit.
GPU can be dropped to a 5700xt if needed. It is around 5-10% slower than 2070 super in some titles while trading blows with 2070 super in some other titles that too for $100 less.
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($189.99 @ Amazon)
Motherboard: MSI B450-A PRO MAX ATX AM4 Motherboard ($99.99 @ B&H)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory ($81.99 @ Newegg)
Storage: Silicon Power A80 1 TB M.2-2280 NVME Solid State Drive ($124.99 @ Amazon)
Video Card: Gigabyte GeForce RTX 2070 SUPER 8 GB WINDFORCE OC 3X Video Card ($499.99 @ Amazon)
Power Supply: Corsair TXM Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply ($83.98 @ Newegg)
Monitor: Samsung C27JG56 27.0" 2560x1440 144 Hz Monitor ($279.99 @ Amazon)
Total: $1360.92
Generated by PCPartPicker 2020-01-19 22:57 EST-0500
