https://au.pcpartpicker.com/list/4VYhK4
I am currently in the process of planning and designing a new pc for a mate of mine. He mostly plays Minecraft, a little bit of Fortnite and might be looking into getting into my graphic intensive games. Knowing this I have opted to go with the Ryzen 5 3400G as it will run well enough for what he wants currently and he can easily add a graphics card when he wants to move onto more graphic intensive games. He wont be looking for more than 60fps as his monitor is 60hz as well as doesn't want to go over a budget of around $800-900. Can any improvements be added to this parts list? any compatibility errors I don't know about? (motherboard and cpu are compatible btw)
I'm open to any suggestions :)
https://linustechtips.com/topic/1146812-build-for-a-friend/
Looks good. Personally, I'd probably go for a B450 Tomahawk MAX (or Gaming Plus, A Pro, etc), as the case allows for an ATX motherboard and this will provide better upgradability in the future. That being said, the B450M PRO-VDH that you've chosen will be enough for the moment, if you don't want to spend extra. Also maybe look for an M.2 NVMe drive, as nowadays they go for pretty much the same prices as SATA SSDs, offer faster speeds and save you from having to run extra cables from the SSD to the motherboard/PSU.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1146812-build-for-a-friend/#findComment-13227659
I don’t the 3400g.  I’d rather put him in a 1600 with a used rx470 or something if possible.  Barely more money but a lot more longevity.
https://linustechtips.com/topic/1146812-build-for-a-friend/#findComment-13227693
a more expensive but much better performing option:
PCPartPicker Part List
CPU: AMD Ryzen 5 2600 3.4 GHz 6-Core Processor  ($195.00 @ Shopping Express)
Motherboard: ASRock B450M/AC Micro ATX AM4 Motherboard  ($138.60 @ Newegg Australia)
Memory: GeIL EVO POTENZA 16 GB (2 x 8 GB) DDR4-3200 Memory  ($96.80 @ Newegg Australia)
Storage: Crucial BX500 240 GB 2.5" Solid State Drive  ($42.90 @ Shopping Express)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($75.00 @ Shopping Express)
Video Card: Asus Radeon RX 570 4 GB Expedition Video Card  ($179.00 @ Umart)
Case: Thermaltake Versa H18 MicroATX Mini Tower Case  ($49.00 @ Centre Com)
Power Supply: Corsair CX (2017) 450 W 80+ Bronze Certified ATX Power Supply  ($72.00 @ Shopping Express)
Total: $848.30
Generated by PCPartPicker 2020-01-19 23:21 AEDT+1100
https://linustechtips.com/topic/1146812-build-for-a-friend/#findComment-13227986
There you go...
Motherboard: ASRock B450M/AC Micro ATX AM4 Motherboard  ($139.70 @ Newegg Australia)
Storage: Crucial MX500 500 GB 2.5" Solid State Drive  ($82.00 @ Shopping Express)
Video Card: Asus Radeon RX 580 4 GB Dual Video Card  ($199.00 @ PCCaseGear)
Power Supply: Corsair CX (2017) 550 W 80+ Bronze Certified ATX Power Supply  ($89.00 @ Austin Computers)
Total: $850.50
Generated by PCPartPicker 2020-01-20 15:39 AEDT+1100
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1146812-build-for-a-friend/#findComment-13229920
