Hi, i have a relatively old case, i know that the wires for the HDD have a negative and positive, does the on/off and reset have a positive and negative to plug them in the mobo?
Sorry for my bad English.
Thank you!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1146806-case-wires/
I've never seen a power or reset switch were the polarity matters, all they are doing is creating a connection between the 2 pins.
You can use a screw driver or something conductive to create the same effect so it shouldn't matter which way they plug in.
https://linustechtips.com/topic/1146806-case-wires/#findComment-13227558
on/off and reset switch doesnt care, all they do is shorting the two pins.
Desktop benching:
https://linustechtips.com/topic/1146806-case-wires/#findComment-13227563
Thanks fot the help @Jurrunio and @Neggy-Z
https://linustechtips.com/topic/1146806-case-wires/#findComment-13227572
