Hey, I could use some help with my build and would be very happy if you could check my config and maybe give me some advice and/or opinion.
Thank you in advance!
Planned so far:
BitFenix Prodigy M
Intel Core i5-4670K
Corsair Vengeance Low Profile black DIMM Kit 8GB, DDR3-1600, CL9-9-9-24
ASUS Gryphon Z87 + Armor Kit (Just for the looks)
3 x be quiet! Shadow Wings SW1 High-Speed 120mm
BitFenix Spectre Pro black 230mm
be quiet! Straight Power E9-CM 680W
be quiet! Dark Rock Pro 3 (Not going to use the HDD mount, so it should fit in)
Samsung Evo 500GB (from my "old" PC)
Also I'm planning to get a GTX 780, usually I'd opt for a ASUS DCU2, but I'm not sure if it'll cause too much heat inside the Prodigy.
https://linustechtips.com/topic/114668-bitfenix-prodigy-m-build-help/
Planned so far:
BitFenix Prodigy M
Intel Core i5-4670K
Kingston HyperX blu. black XMP DIMM Kit  8GB, DDR3-1600, CL9-9-9
should be pretty good. and no it won't put too much heat inside there you got some nice fans there should help too. (it will it you got no exhaust.)
Live your life like a dream.
Edit: http://skinflint.co.uk/?cat=WL-395461 (PcPartPicker dosen't have all the components :c )
The wishlist is blank.
You can add custom parts to pcpartpicker.
