What does hotting “ok” while leaving the fields blank do?
So the PC that hosts the files has a passwordless account?
Then sharing is disabled, you HAVE to have a password for a user to be allowed to access shares.
If you don't want to add a password to the account you log in with you can create another user in the management interface that has a password, that you give permissions to the share to, and which you use for accessing the shares from other computers.
F@H
GPD Win 2
Thank you for the reply...
So to log into windows it has a password - well Pin. and on the Network sharing settings I have turned off password protected sharing.
I hope that helps -
