Hi.
I have to Design a PC For My Dad's Office.
They Need an Alternative System for Adobe InDesign and Photoshop.
The Biggest Problem I am Facing is of choosing between Cores and Cost.
Expected Cost should be Less than 500$.
I Had Previously Planned on using an AMD Ryzen 7 2700X CPU with a Gigabyte B450M-Pro ,But It fell out of budget.
Any Tips anybody
https://linustechtips.com/topic/1146019-pc-build-for-office/
Celeron / ryzen 2200g.
9600KF/ 3600
Ryzen 3600 4.33ghz . CM Hyper 212 Turbo. MSI X470 Gaming Plus Max. Crucial Ballistix Sport LT 3200 @ 3200 CL 15 (OC). Powercolor RX 5700XT Red Dragon. FD Meshify S2. Crucial P1 M.2 1TB. Corsair Vengeance 650W 80+ Silver.
Core 2 Duo 3.4ghz . WenjuFeng cooler . ASUS P5G41C-M LX . Crucial 1066mhz 3GB DDR2 . Gainward Golden Sample HD 4850 . Coolermaster Elite 430 . Seagate 160GB IDE 7200RPM . BeQuiet System Power 9 400w 80+ Bronze
https://linustechtips.com/topic/1146019-pc-build-for-office/#findComment-13221069
Ryzen 1800 with a B350 board?
https://linustechtips.com/topic/1146019-pc-build-for-office/#findComment-13221082
https://linustechtips.com/topic/1146019-pc-build-for-office/#findComment-13221426
I'd say an APU or IGPU. the extra cost for a dedicated GPU makes no sense as far as i can see.
At me or quote me, I want to hear your opinion.
Hopefully anything I say is factually correct. Sorry for any mistakes in advanced.
https://linustechtips.com/topic/1146019-pc-build-for-office/#findComment-13221673
