02 headphone amp/dac no audio
supaginge
i have had the 02 headphone amp/dac for some time now and latley its stopped putingout audio sometimes when I change the output device or wake up from from sleep mode or just reboot, does anyone else experience this? and ifso now can i stop it from happening
i have tried to change the usb port it uses to no effect
i also got it from mayflower electronics
AnimeFAN
snippisnappizipzopboop
Try going into your power management and disable power saving on USB and also go into device manager and disable USB power saving functions on USB root hub things, solved an issue I had with a laser mouse.
Reviews: JBL J33i   M50s   SRH440   Soundmagic PL50
i did the USB root thing, but I can't find the USB power saving settings.
im using windows 7
AnimeFAN
Ok, I did that, but it's still not fixed
I just left a Skype call and all my sound stoped
AnimeFAN
I don't have another computer that I can plug it into
I'm not sure if its fixed yet but I'm now getting a popping sound every few seconds which is really distracting
AnimeFAN
