Recommendations for 1440p monitor or good wide curved 1080p monitor
tophercrunch
Going to be purchasing a 980 ti and would like to upgrade my monitor to something better, any thoughts ?
What is your budget? What games will you be running?
CPU: Ryzen 5 5600x  | GPU: GTX 1070 FE | RAM: TridentZ 16GB 3200MHz | Motherboard: Gigabyte B450 Aorus M | PSU: EVGA 650 B3 | STORAGE: Boot drive: Crucial MX500 1TB, Secondary drive: WD Blue 1TB hdd | CASE: Phanteks P350x | OS: Windows 10 | Monitor: Main: ASUS VP249QGR 144Hz, Secondary: Dell E2014h 1600x900
between 200-300 and current games
current game is too wide lol , give us some type
was looking at a few 30+ inch ultrawide 2560 x 1080p 144hrz monitors. What are anyones thoughts on these ?
Don't go that wide on 1080p.
"And I'll be damned if I let myself trip from a lesser man's ledge"
What do you recommend for a monitor then ?
I cannot recommend a monitor because there are none in your price point.
If you're going ultrawide I'd recommend 3440x1440, however you'd need to double your budget.  I'd wait and save.
Ok, will the 980 ti be able to handle that ?
Is there one that isn't a ultrawide monitor that i would benefit from in that price range or wait ?
What's your definition of handle?
What graphic lvl and frame rate are you hoping to achieve.
i know on max/ultra settings @ 1080p it will get 100 + FPS as for 1440p i'm seeing between 40-60 FPS
it was either a graphics card and monitor upgrade or i was going to get a moderately priced gaming laptop with a 1660 ti card with a 1080p 144hrz display. This is still up in the air, as to not purchasing till about three weeks from now.
