monitor profiles.
RasmusDC
Just curious, i am remodelling my office, so i think i will be re purposing my 55 inch 4K tv from my simulator, just to a normal tv, and looking into a different monitor setup..
currently i have a 1440p SR75 Samsung as my main panel, and where thinking of getting 3x1080p 144-165hz IPS monitors for the racing simulator..
i have 4 display outputs on my 1080ti, 2 HDMI 2.0 and 2 DIsplayport 1.2, can i build profiles. so i either have a spanned 3x1080p setup or my 1 display, since this is how i will use them, either simulator, or desktop work, it will be annoying if i need to do this EACH TIME i want to run a few laps on the sim...
but getting a wider perspective, and maybe higher FPS would be nice.
NVidia Control Panel can do an emulation of bigger/wider display that is actually composed of 3 different ones. Try to do it there.
Purify your Windows 10/11, don't give Microsoft anything that you don't want to share.
https://drive.google.com/open?id=1ZwVs9zrM493rjD42E2Pf0YcOkaW92ZUo
Tips for folding on laptop:
Lazy man wants upgrades from the sky.
https://stats.foldingathome.org/donor/Spakes
