Recently i've been having problems with my network most noticeably while playing league of legends. My ping will fluctuate between the 12-100, and it feels like my input delay is extreme even for the ping.
i'm on wifi with a wireless card. i've tried installing new drivers but it didn't result in any noticeable change so i rolled them back.
this has been going on for a couple of months it used to be remedied by a quick restart but that no longer works, and the network trouble shooter does nothing other than reset the access point.
ive tried running the hex tech tool kit (leagues of legends trouble shooting program) but it didnt seem to help.
i appreciate any advice.
edit: windows 10
 Specs: Cpu intel i7-4790k   Gpu: a reference gtx 980 ti   Mother board: msi Krait edition    ram : 16g of ddr3 corsair vengeance
https://linustechtips.com/topic/1145296-unstable-connection-ping/
3 hours ago, grim9x8 said:
would swapping to a wired connection fix the problem if its just the wifi card?
Yes, That would definitely correct the issue if it is a Wireless Problem. if you don't mind me asking, what router do you have?
Jacob H.
Northern Alabama
Associates Degree - Information Systems
Primary Job: Technology Specialist / Financial Industry
Primary PC (Laptop): Dell XPS 9570 (Core i5 8th Generation, 16 GB RAM, NVIDIA 1050 4GB, 500 GB SSD, 1TB HDD)
21 minutes ago, grim9x8 said:
i have an orbi router all of the software is up to date according to the app.
Okay gotcha. I am not very familiar with the Orbi routers, I have heard great things about them though.
Jacob H.
Northern Alabama
