The problem started occuring about 4 months after me building the PC and never having any problems. It lost input signal and its happing since. Its sometimes working fine for days and sometimes it happens evertime I start the PC. There is no patern in when the problem occurs but there are some different "versions" of the signal loss.
  • starting PC --> monitor isnt getting any input and the VGA EZ debug-LED is on ( indicates GPU is not detected or fail )
  • starting PC --> monitor turns on and I can see the boot screen --> loses input signal and the EZ debug-LED stays off
  • starting PC --> everythings working until I log into windwos --> loses input signal and the EZ debug-LED stays off
  • starting PC --> everythings working --> randomly losing input signal and the EZ debug-LED stays off (sometimes the audio is still running and sometimes its cut off after a view seconds)
A restart of the PC sometimes fixes this but most of the time I have to resart multiple times and wait minutes with the PSU off.
My tries fixing it:
  • checking DP cable and then trying DVI
  • checking monitor with other device (PS3)
  • testing an other monitor
  • checking tempretures of GPU and CPU
  • rebuilding the whole PC
  • complete reset of the system (wipe the ssd and installing everything new, BIOS/CMOS reset and BIOS update to 7A38v98)
  • trying older drivers
Nothing of these tries worked so far so I am asking u guys to help me out. If you have an idea how I could fix this please comment.
PC specs:
  • GPU: ASUS Strix Arez Vega 56
  • CPU: AMD Ryzen 5 2600
  • Mainboard: MSI B450M Pro-VDH Plus
  • RAM: Crucial Ballistix Sport LT V2 2x8GB DDR4-3000
  • PSU: be quiet! System Power B9 600W
  • SSD: Intel 660p m.2 512GB
  • Monitor: Acer XF240H (connected with DP)
  • Windows 10 Pro
https://linustechtips.com/topic/1144612-pc-randomly-loses-input-signal/
