Need card recommendation.
Solved by WPD_ps,
9 hours ago, NoGanksEric said:Well it depends on games and money I guess because the 2700 can power everything up to an rtx2070super without a sweat ^^
And if youre just looking at Nvidia it's fairly simple. Choose if you want rtx or not and then pick a card you can afford.
If it's from the newest gen they'll all be faster than the 1050ti.
But maybe start at the 1660super since cars below that may not be the biggest upgrade. That one is available for about 250 new I believe.
I think imma just get a 1080 or a 1080ti, cause I don't really need an RTX card atm. Thanks for all the info everybody!:D
