Hi Community,
If I have a solid state drive that is encrypted with a bios password, (meaning, it would require a password prior to booting the solid state drive), and I were to take that hard drive and swap it into another computer. Could I boot into that hard drive? Would it work, or will the encryption make the solid state drive boot up in only that initial pc where the password was setup?
HD.
https://linustechtips.com/topic/1144394-does-encryption-of-solid-state-drive-n/
You can't encrypt a drive with a BIOS password. All the BIOS password does, like you said, prevent booting on that PC without that password.
There is no "encryption" on the SSD so it would work fine.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
