Mice I find tricky to clean depending on the mouse. I generally start off with a damp(not soaking wet) cloth and get all the large areas then start working at the crevices with a toothpick and tooth brush.
More links in my profile! Builds: Project(Main Rig): Cosmos Sv2 -- 2nd PC: Old School AMD -- Project: HD4890 Revival,
↓↓↓↓↓↓↓↓ Specs Below ↓↓↓↓↓↓↓↓
Cosmos Sv2:
  • CPU: Intel Core i9 9900K @ 5.1ghz
  • Motherboard: Asus PRIME Z390-A
  • RAM: Corsair Vengeance RGB Pro 32 GB (4 x 8 GB) DDR4-3000
  • GPU: Asus GeForce RTX 2080 Ti 11 GB Turbo
  • Case: Modded Cosmos S (Cosmos Sv2)
  • Storage: Samsung 970 Evo 500 GB M.2-2280 NVME, WD Black SN750 2TB NVMe, 2x WD Red 2TB raid 1, 150GB Toshiba 2.5"
  • PSU: Corsair HX850
  • Display(s): Samsung LC32JG50QQNZA 32.0" 2560x1440 144 Hz, LG 29UM58-P 29.0" 2560x1080 75 Hz
  • Cooling: Custom Loop
  • Keyboard: Corsair K95 Platinum
  • Mouse: Corsair Dark Core
  • Sound: Oboard with Logitech something or other 5.1 speakers and HyperX Headset
  • OS: Win 10 Pro
  • PC Part Picker URL: https://ca.pcpartpicker.com/user/NotSoEpicMods/saved/LYysZL
Old School AMD:
  • CPU: AMD Phenom II x6 1090T
  • Motherboard: Asus Sabertooth 990FX rev1.0
  • RAM: 16GB Patriot Sector 5
  • GPU: XFX HD 7950
  • Case: Cougar MX330-G Glass Window
  • Storage: 2x HyperX 3K 120GB SSD
  • PSU: Corsair 650W
  • Display(s): Samsung 32"
  • Cooling: Hyper 212+
  • Keyboard: Logitech G110
  • Mouse: Logitech M100
  • Sound: HyperX Headset
  • OS: Win 7 Ultimate
