Hey guys, so I I'm building a pc and I'm over budget. I was thinking where I could reduce the price. My original plan wa to go with a V300 120gb ssd and a WD 500gb hd. Now I was thinking in getting a V300 30gb ssd (for the system itself) and a 500gb seagate sshd ( http://www.seagate.com/internal-hard-drives/laptop-hard-drives/laptop-solid-state-hybrid-drive/?sku=ST500LM000 ) It's for laptops, so will it work? What do you think?
https://linustechtips.com/topic/114392-sshd-and-a-small-ssd/
30Gb will not be enough for much of anything. Unless you plan on only installing the os (which will only increase boot times) you will see that fill up immediately. The best use for an ssd would be for a cache or a full system install (including programs)
My System Specs: (Short list) i7 4770k, GTX 780, many SSD's, a 2 TB HDD(deceased :( ), Corsair 650D. Full list: http://pcpartpicker.com/user/kchriz6097/saved/8dh7YJ
Upgrade Plan: Acquire some Black Noctuas then add 16 or 32GB of 2133MHz memory
https://linustechtips.com/topic/114392-sshd-and-a-small-ssd/#findComment-1529210
Do this if you don't have a large amount of files and can tolerate the 250Gb space.
My Best 2013 Bitfenix Prodigy Build  Case: Bitfenix Prodigy White | Motherboard: ASRock Z77E-ITX | CPU: Intel i7 3770k | CPU Cooler: H100i | GPU: GTX 690
Fan Controller: Bitfenix Recon | Ram: Patriot IEM 16GB @ 1600mhz | Primary Storage: 2 x Samsung 840 Pro 256GB | Backup Drives: 2 x Seagate Barracuda 2TB | PSU: Seasonic X850
https://linustechtips.com/topic/114392-sshd-and-a-small-ssd/#findComment-1529272
errr out of those 2 options definitly go with the 120gb ssd and the 500gb HDD. ussuallly u can get a 1tb drive for the same-ish price so check that out
https://linustechtips.com/topic/114392-sshd-and-a-small-ssd/#findComment-1529310
