Hi all,
Looking at putting together a build with a 3950x and a Asus Crosshair VIII Hero and struggling with memory choice.
Thisis going to be an Unraid build (upgrading current server) and I'd like 64gb, but don't want to leave too much on the table gaming performance wise. We seem to get raped over here in the UK with prices on anything but Corsair, I see G Skill going for much cheaper in the US/Canada.
Would 3600C17 really be that much of a downgrade compared to 3600C16 or 3200C14 as a 32gb kit of 3600C17 is around £200 where as the others are over £300 generally?
https://linustechtips.com/topic/1143253-memory-advice-x570/
there is uk.pcpartpicker so no problem
in max potential or just at rated settings?
Desktop benching:
https://linustechtips.com/topic/1143253-memory-advice-x570/#findComment-13198732
Sounds like the expensive kits are Samsung b-die.  The difference between the kits I think is gonna be about a handful of frames so it's not something you'll notice unless you measure it.  So unless you like measuring and competitive benchmarking -- I don't think you're gonna be too upset with the cheaper kits.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1143253-memory-advice-x570/#findComment-13198824
34 minutes ago, Stu_Bear said:
3600c17 is fine...I'd not worry about it.  I'm running CAS 17 ram on my home pc...scores in the 99th percentile in all areas.
Running a odd number CAS on ryzen isn't a good idea, by default this turns off gear down mode and can cause stability issues.
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
https://linustechtips.com/topic/1143253-memory-advice-x570/#findComment-13198835
At rated settings, looking for stability really.
Ah nice, thanks for the feedback.
Hopefully I'll be okay then.
I had seen something relating to that. Seems like a minefield with Ryzen.
https://linustechtips.com/topic/1143253-memory-advice-x570/#findComment-13198870
This isn't always the case.  It's an issue with weaker kits or larger capacity kits so it covers many of the kits out there, but something like a 16GB 3600CL15 Samsung b-die kit will run its 15-15-15-15 XMP/DOCP profile with Geardown enabled.
https://linustechtips.com/topic/1143253-memory-advice-x570/#findComment-13198875
1 minute ago, Stu_Bear said:
That's news to me...glad you responded.
Third gen ryzen with its memory improvements may have changed these facts as I haven't upgraded from 2700x yet plan on a 3950x when taxes show up.
Its not that you cannot do it but every system I have helped OC ram running CAS at a odd number almost never results in a Stable OC. Due to gear down gets disabled.
Generally lower bined kits you will run into this issue.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1143253-memory-advice-x570/#findComment-13198896
You can NOT run odd timings with geardown enabled. XMP is a Intel spec the only reason AMD motherboards can run it is because the manufactures have the profiles and bake them into AMD boards. So yes you can run a 15-15-15-15 XMP profile but geardown will be disabled on ryzen. It will automatically force timings to even numbers if you enable geardown on a odd CAS kit. Intel can run odd number of timings anytime because intel cpus don't support gear down mode.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1143253-memory-advice-x570/#findComment-13198919
Just to clarify, I won't be overclocking at all and ideally want 64gb, although will probably buy 32gb to start off.
you need to enable xmp or docp in bios anyway to get ram to run at the advertised speed. otherwise it will be 2133 or 2400 regardless of what kit you buy
https://linustechtips.com/topic/1143253-memory-advice-x570/#findComment-13198933
Isnt Corsair selling 64GB 3000MHz/3200MHz CL16 kit for about 260 pounds? I'd rather get that. You wont lose that much performance and you could compensate some of it by just raising the FCLK
Desktop benching:
https://linustechtips.com/topic/1143253-memory-advice-x570/#findComment-13198938
Yeah, about £270-£280. It seems like a good deal I just didn't want to be losing too much. I might be overthinking it.
Yeah, I'm aware of that but I wouldn't want to bother tweaking past doing that.
https://linustechtips.com/topic/1143253-memory-advice-x570/#findComment-13198991
Crap.  I misremembered having done it with my kit.  It would have been a while ago so I probably am misremembering being able to do it as I can't reproduce it now.  That means I've been spreading damn dirty lies.  That's my bad.
https://linustechtips.com/topic/1143253-memory-advice-x570/#findComment-13199004
3 hours ago, Stu_Bear said:
How high can you crank FCLK on an AMD mobo/chip?  Intel cuts you off at 102.9 :(
You're talking BCLK in that case, not FCLK. Ryzen corrupts NVMe SSDs with BCLK over 101MHz so it's really not worth doing.
Desktop benching:
https://linustechtips.com/topic/1143253-memory-advice-x570/#findComment-13199549
35 minutes ago, cobhc said:
So going for a 64gb set of 3200CL16 won't leave too much on the table performance wise and I'll have less chance of stability issues?
If you going to go with a 3200 kit i could go with a CL14 kit or a 3600 kit CL16.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1143253-memory-advice-x570/#findComment-13200801
