I know I’m not running the best of hardware but what I’m experiencing doesn’t make sense. My old card is the sapphire r9 270x 2gig and was getting a stable 60 FPS on gta 5.
i installed evga gtx 960 4gig card and current drivers I’m getting unstable 30 to 50 FPS nothing else has changed in hardware. What could be causing this???
https://linustechtips.com/topic/1143102-help-drop-in-fps/
Check temps. Could be bad thermal paste causing throttling.
Main PC: ROG Zephyrus G14 2020
CPU : AMD Ryzen 7 4800HS |
RAM : 16Gb DDR4 |
GPU : Nvidia GTX 1660Ti Max Q |
Storage : 512Gb NVme SSD |
Secondary PC:
CPU Xeon E5 2620 v3 |
Mobo : Jingsha X99 D4 |
RAM : 16Gb DDR4 |
Cooler : Deepcool Ice Edge Mini FS V2 |
GPU : Nvidia GTX750Ti |
Storage : Samsung 860 EVO 250gb (OS) |
PSU : Super Flower SF-500R12N |
Case : Cube Gaming Fernos |
Peripherals:
Monitor : AOC 24G2 |
Keyboard : Digital Alliance Meca Fighter Ice - Akko CS Vintage White |
Mouse : HyperX Pulsefire Haste |
Headphones : Phillips SHP9500 |
Mic : Taffware BM800 |
Mic Arm : Some cheap bogstandard arm |
https://linustechtips.com/topic/1143102-help-drop-in-fps/#findComment-13197480
4 minutes ago, Nerzule said:
When the card goes under load during game play the temp is around 67-71 degrees
50 minutes ago, emosun said:
did you clean the old drivers or just install everything on top of the old software.
-Scott Manley, 2021
https://linustechtips.com/topic/1143102-help-drop-in-fps/#findComment-13197509
Those temps are nowhere near anything to worry about.  What CPU and GPU usage % are you seeing while in game?
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/1143102-help-drop-in-fps/#findComment-13197510
The gtx 960 is not that much faster than 270x. Yes it has more vram, so its better at higher resolutions. And its not even close to best hardware.
That is very good for the gpu.
Mayby you changed the graphics? Also be sure that the card is getting enough power, sometimes it gets blue screen sometimes it lowers the performance(very rare)
Tell us your pc specs.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1143102-help-drop-in-fps/#findComment-13197513
