I build and sell PCs as a hobby. Sometimes I keep parts for my personal rig. I have been running an RX 580 for about a year.
I recently scored a great deal on an EVGA 1070ti on ebay for $205 (Mislabeled as a 1070). It has about a year left on the warranty so I swapped out the 580 and built a more budget oriented rig for resale.
I'm having second thoughts now. Is the card getting a little old now? A 1660 super is not much more money brand new. Should I sell it and wait for something newer?
https://linustechtips.com/topic/1143064-keep-1070-ti/
Nah the card is fine. It seems it performs slightly better than the 1660 Super, but I suppose it will be missing any of the latest driver features Nvidia enabled only for the latest generation of GPUs.
https://www.videocardbenchmark.net/compare/GeForce-GTX-1070-Ti-vs-GeForce-GTX-1660-SUPER/3842vs4159
The Daily Driver:
AMD Ryzen 7 3700x  |  EVGA GTX 1070 SC  |  48GB Crucial Ballistix Elite DDR4-3600  | Corsair 750D Case
AsRock X570 Pro 4 mobo
iRacing Sim Rig:
i5-10600k @ 5.0 GHz  |  EVGA GTX 1080ti Hybrid  | 32GB G.Skill Trident Z Neo DDR4-3600  |  Corsair Air 540 Case
ASUS Z490-E ROG Strix mobo
https://linustechtips.com/topic/1143064-keep-1070-ti/#findComment-13197063
It's a very capable card that can net you about $240.  A 1080 ti is worth about twice that while the 1070 ti can run very strong in 1080p/1440p/reduced 2160p.  If you run any of those resolutions then compare that against the 580 performance (I don't have one) and determine what matters more . . . the money or the performance.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1143064-keep-1070-ti/#findComment-13197068
The 1660S might not be much more money, but what are you really getting in return? More warranty? So what. With PC parts chances are if it's not dead on arrival, it's not going to just suddenly crap out unless you're putting it under some pretty significant stresses. Which you're not, if you're just gaming.
$205 is a decent deal. Not amazing. I usually see them around the $240 mark. So you could sell it for what? $35? Doesn't really seem worth it.
Just keep it. The 3000 series comes out in the summer, and if you see decent performance gains then that's when I'd consider upgrading.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1143064-keep-1070-ti/#findComment-13197104
Yeah I think I'll keep it. I can always put it in another rig down the road.
https://linustechtips.com/topic/1143064-keep-1070-ti/#findComment-13197130
