Clean it then, or next time actually spend some effort on your threads asking for help.
https://linustechtips.com/topic/1142121-help-overheating-gpu/#findComment-13188930
Make sure that your airflow is decent inside your case and that the heatsinks on your card are clean. 86C doesn't seem to be too bad as long as it is not thermal throttling and you are fine with the fan noise, but it is still pretty hot.
PC:
AMD Ryzen 9 5900X | AMD Radeon RX 7900 GRE | 32 GB RAM | Arch Linux
Laptop:
MacBook Pro 13" (2019) | Intel Core i5 8279U | 8 GB RAM | macOS
Server:
Intel Core i7 6700K | 16 GB RAM | 2 TB HDD | Debian Linux
https://linustechtips.com/topic/1142121-help-overheating-gpu/#findComment-13188936
53 minutes ago, SpanishOmega said:
I don’t got an exhaust fan in my case atm. And it’s not throttling and stays pretty quite.
Well then it's not overheating. Nothing to worry about. I would get an exhaust fan for your case though.
PC:
Laptop:
Server:
https://linustechtips.com/topic/1142121-help-overheating-gpu/#findComment-13189825
It may not be thermal throttling below stock clock speeds, but it's almost certainly not going to be boosting as high as it could.  Your temps are safe, but there's room for improvement.
Make sure the heat sink is clean, makes sure case airflow is good (a rear exhaust fan will help here), and if desired you can increase the fan curve a little to see if that helps the temps lower down a bit.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
https://linustechtips.com/topic/1142121-help-overheating-gpu/#findComment-13189873
Thank you for the help.
https://linustechtips.com/topic/1142121-help-overheating-gpu/#findComment-13190097
Thank you for the assistance.
https://linustechtips.com/topic/1142121-help-overheating-gpu/#findComment-13190101
