Hello, i bought new microphone but it's not working properly. There's really annoying buzz, noise in the background also volume of my voice is really low on 0Db boost. Also there's no enchantments tab in microphone settings.
I tried:
-reinstalling drivers from my mobo website
-reinstalling drivers from realtek website
-checking front panel (actually voice on front panel is better)
 Intel i5-9600K Nvidia GTX 1060 Gaming G1Gigabyte Z390 Gaming X │ Corsair RM550x │ Cryorig Universal H5 │Corsair Vengeance LPX DDR4 16GB (2x8GB) 3000MHZ CL15
https://linustechtips.com/topic/1141882-microphone-problem/
Maybe telling us the mic would happen?
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
https://linustechtips.com/topic/1141882-microphone-problem/#findComment-13187063
It's Mozos MKIT 800PRO
I tried microphone on other computer and works fine so i think my Z390 Gaming X mobo just have bad audio card?
https://linustechtips.com/topic/1141882-microphone-problem/#findComment-13187071
Not much comes up when I search that. It appears to be an XLR mic. Are you not using an audio interface, such as a Focusrite https://www.amazon.com/Focusrite-Scarlett-Audio-Interface-Tools/dp/B01E6T56EA
https://linustechtips.com/topic/1141882-microphone-problem/#findComment-13187118
No, i don't use audio interface.
i'm totally casual when it comes to microphone topic.
https://linustechtips.com/topic/1141882-microphone-problem/#findComment-13187128
