hello
i have weird GPU buzzing, when PC is off (hard to tell if it has buzzing when on, because fans are louder) and even when i unplug power cables it still buzzing, only when i take it out from PCIe slot, then it stops buzzing
also yesterday i installed new MB gigabyte x570 aorus master and i had several times looping LEDs CPU -> DRAM -> VGA, i think after VGA it should be BOOT led, when it start to load OS, but after few Loops MB resets BIOS
could it be some kind of GPU problem, that doesn't let PC boot and smart BIOS resets itself
my pc:
Ryzen 3700x
gskill 2x 8Gb - XMP 3600 16-16-16-36-52 1T
EVGA 1080 hybrid
EVGA 850W G3 supernova gold
Samsung M2 970 evo 280Gb
Crucial MX500 1TB SATA
https://linustechtips.com/topic/1141819-need-help-with-gpu-buzzing/
i forgot to mention, that i tried to put in my friennd's Gygabyte 1060 3Gb GPU and it didn't had that buzzing sound
also when i turn off PC and GPU buzzing, then DRAM LED is on, even PSU is unpluged from MB and GPU and stays until i remove GPU, then DRAM LED is off and when i put GPU back into PCIe, then DRAM LED is still off and GPU aren't buzzing
From what you are describing, this buzzing is most probably coil-wine and there isn't really a way around it. Technically manufacturers do not consider it an issue and is not covered under warranty. So your best bet is to return the card if the 14-day return period applies in your country / state.
Regarding the power-cycling of your system, I doubt it is related to the graphics card, because the graphics card isn't required for the PC to complete the post. Meaning, even if you didn't have it installed, it shouldn't make any difference whatsoever. Therefore, my guess is that this power cycling is caused by your RAM. Go back and set the RAM to the default (2400Mhz) and see how it is. I bet the power-cycling will go away.
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
I am using XMP profile which runs at 3600Mhz speed with 16-16-16-36-52 1T, also i did prime95 test and there wasn't any error after running it ~30mins, with my old MB i had an error even at 3400Mhz speed
so i am thinking that it is GPU issue, because it doesn't pass VGA LED and that LED stays longer than CPU and DRAM
i am thinking that when i am closing case side panel, then it pushing power cable and liquid tubes and something happens that trigger an issue
That my friend like suggested above is coil whine! Its not defective. Just the coil vibrates at a certain audible pitch. Its also the reason for some real bargains! My previous dell xps had a list price of £1200, it was returned to seller. I bought it as an open box return a month after it was launched for £800! You could just about hear it if you put your ear to the keyboard lol.
Back on topic, if you can identify the coil thats whining a simple and easy fix is blu tac! Just a small bit around the coil, stop all audible sound!
Gaming PC: • AMD Ryzen 7 3900x • 16gb Corsair Vengeance RGB Pro 3200mhz • Founders Edition 2080ti • 2x Crucial 1tb nvme ssd • NZXT H1• Logitech G915TKL • Logitech G Pro • Asus ROG XG32VQ • SteelSeries Arctis Pro Wireless
Laptop: MacBook Pro M1 512gb
Yup, if you can isolate whats "whining" you could technically use that goop to keep it from vibrating.  If you were to crack a PSU open, that's what they do to keep those coils from whining (huge globs of adhesive)
Workstation Laptop: Dell Precision 7540, Xeon E-2276M, 32gb DDR4, Quadro T2000 GPU, 4k display
Wifes Rig: ASRock B550m Riptide, Ryzen 5 5600X, Sapphire Nitro+ RX 6700 XT, 16gb (2x8) 3600mhz V-Color Skywalker RAM, ARESGAME AGS 850w PSU, 1tb WD Black SN750, 500gb Crucial m.2, DIYPC MA01-G case
My Rig: ASRock B450m Pro4, Ryzen 5 3600, ARESGAME River 5 CPU cooler, EVGA RTX 2060 KO, 16gb (2x8) 3600mhz TeamGroup T-Force RAM, ARESGAME AGV750w PSU, 1tb WD Black SN750 NVMe Win 10 boot drive, 3tb Hitachi 7200 RPM HDD, Fractal Design Focus G Mini custom painted.
NVIDIA GeForce RTX 2060 video card benchmark result - AMD Ryzen 5 3600,ASRock B450M Pro4 (3dmark.com)
Daughter 1 Rig: ASrock B450 Pro4, Ryzen 7 1700 @ 4.2ghz all core 1.4vCore, AMD R9 Fury X w/ Swiftech KOMODO waterblock, Custom Loop 2x240mm + 1x120mm radiators in push/pull 16gb (2x8) Patriot Viper CL14 2666mhz RAM, Corsair HX850 PSU, 250gb Samsun 960 EVO NVMe Win 10 boot drive, 500gb Samsung 840 EVO SSD, 512GB TeamGroup MP30 M.2 SATA III SSD, SuperTalent 512gb SATA III SSD, CoolerMaster HAF XM Case.
https://www.3dmark.com/3dm/37004594?
Daughter 2 Rig: ASUS B350-PRIME ATX, Ryzen 7 1700, Sapphire Nitro+ R9 Fury Tri-X, 16gb (2x8) 3200mhz V-Color Skywalker, ANTEC Earthwatts 750w PSU, MasterLiquid Lite 120 AIO cooler in Push/Pull config as rear exhaust, 250gb Samsung 850 Evo SSD, Patriot Burst 240gb SSD, Cougar MX330-X Case
