I have an rtx 2070 super from asus and an i7 7700 (non k) is it worth upgrading to a better cpu? (if yes and you can recommend pls do) i play 1440p 144hz
My Build
Case:Lian-li O11 Dynamic white | Processor:Ryzen 9 5900x | CPU Cooler:Kraken X73 | Motherboard: gigabyte B550 vision D | Graphics Card:Asus ROG Strix Gaming Geforce RTX 3080 10GB OC | Ram: G.skill Trident Z Royal 32G(16x2) cl16-16-16-36 | Psu:Corsair HX1000 80+ Platinum | Storage: Samsung 970 EVO Plus 2TB + Crucial P2 2TB + Samsung 860 EVO 1TB | Case fans: 9 EK-Vardar EVO 120ER D-RGB |
https://linustechtips.com/topic/1141816-upgarde-cpu-or-not/
Only upgrade if your current CPU isn't doing something you want it to. If you are primarily gaming, the i7-7700 will be a great CPU for literal years to come
The Daily Driver:
AMD Ryzen 7 3700x  |  EVGA GTX 1070 SC  |  48GB Crucial Ballistix Elite DDR4-3600  | Corsair 750D Case
AsRock X570 Pro 4 mobo
iRacing Sim Rig:
i5-10600k @ 5.0 GHz  |  EVGA GTX 1080ti Hybrid  | 32GB G.Skill Trident Z Neo DDR4-3600  |  Corsair Air 540 Case
ASUS Z490-E ROG Strix mobo
https://linustechtips.com/topic/1141816-upgarde-cpu-or-not/#findComment-13186490
I think you should be fine for another 1-2 years with the 7700, if all you do is gaming. If you want to check for yourself whether your GPU is being bottlenecked, just check your CPU and GPU's usages while gaming with something like MSI Afterburner. Ideally, you want your GPU to run at 90-100% usage, with your CPU not going over 80-90%, but as long as you don't notice stuttering and frametimes are consistent, then you should be good.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1141816-upgarde-cpu-or-not/#findComment-13186506
