You could go as cheap as the i3-9100F but R5 3600 is the best if future upgrades is concerned, just use the same CPU over and over again when the GPU gets swapped out multiple times.
Desktop benching:
https://linustechtips.com/topic/1141647-best-cpu-for/#findComment-13185164
how are second gen ryzen prices in your country @Narendra5155 ?
Here, 2700x is ~30 USD cheaper, than 3600, whereas the 2600x is ~15 USD cheaper than 9400f. If you have similar prices locally, you might even consider any of those..
Life is really challenging. I don't always suceed: )
https://linustechtips.com/topic/1141647-best-cpu-for/#findComment-13185838
3 minutes ago, Narendra5155 said:
in india
Ryzen 5 2600    = 12499 Rupees (174 USD)
Ryzen 5 2400G = 10581 Rupees (147.50 USD)
Intel i5 9400F    = 11900 Rupees (166 USD)
Intel i3 9100F    = 6849 Rupees   (91.50 USD)
on amazon i just checked.
at those price points the 9400F is the most sensible choice
https://linustechtips.com/topic/1141647-best-cpu-for/#findComment-13186052
