Yeah it'll work but they're usually super overpriced.
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/1141554-i7-5775c-help/#findComment-13184324
Just now, What do I have to put here said:
Yeah I just checked ebay. They are so expensive . isn't it just better if I would get an i7 4790k or 4770k?
Check out Xeon E3 1240v3. They're like i7s but they were branded for corporate use. You can't overclock them but they're usually a lot cheaper.
If you'll be spending the money on a i7 might as well spend just a little more for a Ryzen upgrade
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/1141554-i7-5775c-help/#findComment-13184343
Bid on a 4770K instead, you can get them close to $100
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1141554-i7-5775c-help/#findComment-13184364
5th gen is actually the peak of Intel IPC before all the bug fixes, though their frequency potential can be absolute trash.
Desktop benching:
https://linustechtips.com/topic/1141554-i7-5775c-help/#findComment-13184378
