Hello guys!
I'm looking for advices on what build to go with! I made 2 builds and I want someone to tell my all he thinks about them....which is better for money, gaming, performance and If you have any other suggestions to tell me. Finally tell me what you advice me to go with...The difference between them is like 20 Euros so I have no problem with that!
Here are my builds:
AMD BUILD
INTEL BUILD
Thanks in advance!  :D
https://linustechtips.com/topic/114144-build-advice/
you should add a 212 evo to the intel otherwise you wasted money on a ocing cpu
Specs
https://linustechtips.com/topic/114144-build-advice/#findComment-1525507
Is it just me or is this really hard to read on the night theme? Maybe I'm colour blind.
I'd go with the Intel build. Most games don't use more than 4 cores, and the 4670K is more powerful per core, so it should do better.
Just note that a 32GB SSD is not enough for a C: drive. It will fit the OS, but will fill up VERY fast. Go for at least 60GB, 120GB ideally
https://linustechtips.com/topic/114144-build-advice/#findComment-1525510
so what cpu should I buy if I'm not going to oc my cpu?
just a i5 4670
Specs
https://linustechtips.com/topic/114144-build-advice/#findComment-1525514
https://linustechtips.com/topic/114144-build-advice/#findComment-1525515
I was thinking to install windows on SSD and leave other apps on the normal HDD.
https://linustechtips.com/topic/114144-build-advice/#findComment-1525517
Here, this is better for the intel build. You may want to stretch to fit a CPU cooler in
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($224.99 @ Amazon)
Motherboard: Gigabyte GA-H87M-HD3 Micro ATX LGA1150 Motherboard ($84.98 @ SuperBiiz)
Memory: A-Data XPG V1.0 4GB (1 x 4GB) DDR3-1600 Memory ($27.99 @ Newegg)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Disk ($69.99 @ Microcenter)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($59.99 @ Amazon)
Video Card: Asus Radeon R9 270X 2GB Video Card ($222.98 @ SuperBiiz)
Case: BitFenix Shinobi Window ATX Mid Tower Case ($76.57 @ NCIX US)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply ($39.99 @ Microcenter)
Total: $835.47
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-02-11 07:28 EST-0500)
https://linustechtips.com/topic/114144-build-advice/#findComment-1525524
Can you make a similar build with an Intel proccessor that I won't OC please?
Even though you wont OC, the 8320 would be better in this build, and aftermarket coolers never hurt
CPU:  AMD FX-8320 3.5GHz 8-Core Processor  ($149.99 @ Amazon)
Motherboard:  Asus M5A97 LE R2.0 ATX AM3+ Motherboard  ($64.99 @ Newegg)
Memory:  Corsair XMS 8GB (1 x 8GB) DDR3-1600 Memory  ($64.99 @ Newegg)
Video Card:  Asus GeForce GTX 770 2GB Video Card  ($309.99 @ NCIX US)
Case:  BitFenix Shinobi Window (White) ATX Mid Tower Case  ($86.98 @ SuperBiiz)
Total: $867.90
(Generated by PCPartPicker 2014-02-11 07:31 EST-0500)
https://linustechtips.com/topic/114144-build-advice/#findComment-1525527
I do that with mine, but things still get stored on the C: drive whether you want it to or not. I had a 60GB drive and got to the point of only having 5GB free without installing any programs on it.
https://linustechtips.com/topic/114144-build-advice/#findComment-1525528
https://linustechtips.com/topic/114144-build-advice/#findComment-1525532
He said he doesn't OC so I win.
https://linustechtips.com/topic/114144-build-advice/#findComment-1525538
OK, im just going to say what's on everyone's mind.Y U NO OC?! Its free performance and is rreeeaaalllyy easy. And if you're not comfortable with it atm, you might be later on down the road. Who knows? OCing is always a good option, and its there if you want it. No harm will be done.
https://linustechtips.com/topic/114144-build-advice/#findComment-1525547
I'm scared of OCing....Is it really easy as they say? I may harm my system..
https://linustechtips.com/topic/114144-build-advice/#findComment-1525557
Total: $835.47
I like this build...Will 500w be enough?
https://linustechtips.com/topic/114144-build-advice/#findComment-1525562
For the time being there is no real reason to overclock a 4670K. You will see no difference in gaming performance. You will only really see differences in CPU intensive stuff.
Made this. Best of both worlds. You get the 120GB SSD, good Intel CPU, and a more powerful GPU
CPU: Intel Core i5-4570 3.2GHz Quad-Core Processor ($196.98 @ Amazon)
Storage: Hitachi Ultrastar 1TB 3.5" 7200RPM Internal Hard Drive ($51.00 @ Amazon)
Total: $885.48
(Generated by PCPartPicker 2014-02-11 07:38 EST-0500)
https://linustechtips.com/topic/114144-build-advice/#findComment-1525568
Yep, 500 will be enough. You could always go for the 600w if you're really worried, it's only $10 more. You'll be fine with the 500w though. The build with the Nvidia card is the best price/performance option I think.
https://linustechtips.com/topic/114144-build-advice/#findComment-1525576
Total: $885.48
Is it really better to go with gtx 770 instead of r9770x?
https://linustechtips.com/topic/114144-build-advice/#findComment-1525586
Oh god my eyes!
Comic sans we meet again
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/114144-build-advice/#findComment-1525613
