Not to sure where to post this (so please correct me) but here goes,
I have been seeing this thing that a lot of people have like Admins and Moderators which are badges of sorts, and was wondering how you add them to a forum as me and my friend are setting up a company and are wanting to make a community forum and I have made badges but don't know how to have them appearing like they do in this forum for admins and moderators.
Example:
Cheers,
Tom
https://linustechtips.com/topic/1141141-forum-advice/
What forum software are you using?
This forum uses IPB (version 4), which has native support for badges, but I am not sure how you can custom add them. But I am sure that's very possible in all forum software packs!
PHPBB is another forum software I know, which likely handles things differently, so knowing what software you use will make it easier to tell you.
https://linustechtips.com/topic/1141141-forum-advice/#findComment-13181001
I'm using the same one. I'm trialing out the demo of this forum because when I start work again I'm going to use some of the money towards our community forum.
Cheers,
Tom
https://linustechtips.com/topic/1141141-forum-advice/#findComment-13181008
I managed to do one in the forum that I'm creating but it had the About Me text above it and I don't want the About Me text with it I just want the badge and the title xD
https://linustechtips.com/topic/1141141-forum-advice/#findComment-13181025
Unfortunately I have never worked with IPB, so I don't know how to add this.
For what it is worth, it seems like the 'cAuthorGroupIcon' class is where the badge is listed and I see some plugins like this:
http://invision-virus.com/forum/index.php/files/file/2067-hq4-badges/
But I am not sure how that all works.
https://linustechtips.com/topic/1141141-forum-advice/#findComment-13181044
Will have a look at it thanks! And when I download it will it go straight to the Invision admin panel or do I have to download it to my computer?
https://linustechtips.com/topic/1141141-forum-advice/#findComment-13181058
I don't know. That is something I found online that seems to fit your usage, but I am not sure if it's actually even legit or whatever.
You could try to contact Invision's support to see if they can help you out a bit with this (or wait for someone with experience in this to roll into this thread)
https://linustechtips.com/topic/1141141-forum-advice/#findComment-13181063
Yea might wait a little while to see if somebody rolls in to the thread if not I'll message the support team at Invision because I wasn't sure that website seemed legit which is why I didn't want it downloading to my computer xD
https://linustechtips.com/topic/1141141-forum-advice/#findComment-13181075
Hey, I decided to look up a bit more about this. This forum thread might help you out:
https://webflake.sx/topic/22184-group-icon-on-forum/
https://linustechtips.com/topic/1141141-forum-advice/#findComment-13184637
