DP and sound
Go to solution Solved by BTGbullseye,
5 hours ago, C2dan88 said:
DP can carry sound same as HDMI
Almost the same... It doesn't support Audio Return Channel. In all other respects however, it works effectively the same.
Hi Guys,
Just need to confirm something.
I have the RTX2060
3 monitors
Main Monitor: DP to DP Cable
2 Side Monitors DP to HDMI Cables.
Just updated the drivers for the 2060, and the audio switched to one of the side monitors that has in-built speakers.
I was able to fix that, but I thought DP did not have any Audio channels...? So how did the sound move to a DP-HDMI connected monitor?
Another thing, the Main Monitor is LG 32" 144 Hz FreeSync, and is working at 144 Hz with the 2060 as it is compatible with G-Sync. If I replaced the DP-DP cable with a HDMI-HDMI cable, will it still work at 144 Hz refresh rate?
https://linustechtips.com/topic/1141062-dp-and-sound/
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
https://linustechtips.com/topic/1141062-dp-and-sound/#findComment-13181375
