Hey my pc has a i7 9700k, msi 2070s and im pretty sure i have sufficient enough fans to cool down my cpu but when i do games for 1+ hours it heats up above  90 °C and around 100 and the gpu heats up to around 80 to 90 degrees. is this
normal? if not what should i do. i have not overclocked at all unknown.png    Im using Hw monitor for the temperatures and at idle it normally hovers around 45 to 55
https://linustechtips.com/topic/1140242-overheating/
What cpu cooler? vcore at max load? Did you disable all auto oc in the bios?
https://linustechtips.com/topic/1140242-overheating/#findComment-13174021
6 hours ago, Crunchy Dragon said:
How is your case airflow?
i have to intake fans and one exhaust fan. it flows from the dront of the case to the back io
its a coolermaster geminII m5.
its a coolermaster geminII m5. and i didnt see anything about auto oc in bios and and the voltage for the cpu when at max load is between 1.290 and 1.350
https://linustechtips.com/topic/1140242-overheating/#findComment-13174023
Your temps seem hotter than normal, you might want to add more fans. With intel CPUs you can generally do a negative voltage offset and keep it stable. I have a 9700k that I run at 4.8ghz all core with a -.02 mv offset on the cpu.
https://linustechtips.com/topic/1140242-overheating/#findComment-13174054
This cooler is total crap for an i7 9700k
You think that 2 intake in the front and one exhaust in the back is a good air fow?
Well it's not at all!
If you have empty slots put fans everywhere and try to keep a positive pressure
I myself have 5 intake and 1 exhaust to keep the case cool!!
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1140242-overheating/#findComment-13174056
You have a small cpu air cooler. You are gonna need a big boy air cooler  to manhandle 9900k heat. 1.29v to 1.35v is a lot for 9900k. Offset voltage your cpu to 1.25v to see if it stable with good temp. Unfortunately, your board is overvolt the cpu at stock. Disable something like MCE(MultiCoreEnhancement) in bios if you see any.
https://linustechtips.com/topic/1140242-overheating/#findComment-13174058
OP have an 9700k :)
https://linustechtips.com/topic/1140242-overheating/#findComment-13174062
whats a good cooler but capable to do overclocking with?
i have an i7 9700k
https://linustechtips.com/topic/1140242-overheating/#findComment-13174065
You can see it in my gallery in my profile.
I have 2 front, 2 top, bottom, 1 back
https://linustechtips.com/topic/1140242-overheating/#findComment-13174070
The new CoolerMaster Hyper 212 Black Edition, ad a second fan, push pull and you are just fine
And it cost 30$
https://linustechtips.com/topic/1140242-overheating/#findComment-13174075
Just now, LightDragon1023 said:
wouldn't that create airflow problems or not effiecent?
Air flow is what we need!!
https://linustechtips.com/topic/1140242-overheating/#findComment-13174076
do you mean that the cooler is 30$ or the fan?
the cooler with the fan cost 30$
if you want to add another one for push/pull it cost around 20€
https://linustechtips.com/topic/1140242-overheating/#findComment-13174080
no as in if your pulling air in from the front of the case and your also having air pulling in from the top as well would the air be in a way pushed down?
My case is inverted the 2 top fans blow air directly to the GPU.
Look in my profile i have pictures
https://linustechtips.com/topic/1140242-overheating/#findComment-13174084
so basically it would cost me around 100$(for me. i live in aus)
30+20=50$
Where did the 100$ came from?
https://linustechtips.com/topic/1140242-overheating/#findComment-13174087
This is your issue. You don't need better cooler. Its top-flow cooler, but fine for its price range. The auto-OC referenced hear is Multi-Core Enchantment which is on by default. Disabling it will get temps down. You can further get them down by setting voltage offset. 1.29V is something you only need when OCing. Your actual load voltages should be closer to 1.2V or even under that.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1140242-overheating/#findComment-13174531
