Hi i bought this memory and put it on order few minutes ago because im trying to match the qvl sheet. Is this memory any good? I know i dont need the 64gb but money isnt a problem and im trying to match the qvl sheet. https://www.newegg.com/product/N82E16820236463?m_ver=1 Can somebody check it out
https://linustechtips.com/topic/1140155-please-help/
It’s very overpriced but also corsair and rbg so normal small brain conventions are out the door
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
https://linustechtips.com/topic/1140155-please-help/#findComment-13173157
Just now, charbel1011 said:
Decent? Whats better? Whats the best?
that's a rabbit hole with no end, usually corsair gets close to the line of best, but doesn't actually cross it. and the 0.002% performance you'd gain is actually negligible.
https://linustechtips.com/topic/1140155-please-help/#findComment-13173223
So what i wanna know is that memory going to be good with my i9 9900k. And maximus xi code or not for gaming at 3440x1440?im sorry im newb to building pcs
https://linustechtips.com/topic/1140155-please-help/#findComment-13173226
intel doesn't scale with memory speeds, after whatever it's rated for is purely negligible unless you use the integrated graphics
https://linustechtips.com/topic/1140155-please-help/#findComment-13173229
7 minutes ago, charbel1011 said:
Im gonna use my 2080 ti. So i should be good?
RAM is only for the CPU, all your other components have nothing to do with each other except for motherboard.(and if it's a new motherboard then compatibility is rarely an issue with all components.
https://linustechtips.com/topic/1140155-please-help/#findComment-13173269
I just wanna know one thing that memory i picked is c16 not c14 is there huge difference?
https://linustechtips.com/topic/1140155-please-help/#findComment-13173294
on the store listing it tells you, and it makes a suck a minuscule difference difference that it's easier to say that there isn't
https://linustechtips.com/topic/1140155-please-help/#findComment-13173315
I'd probably opt for this... as timings are tighter and it's optimized for Intel :)
https://www.amazon.com/HyperX-Predator-3600MHz-HX436C17PB3K4-64/dp/B07GN5HBPQ/ref=sr_1_8?keywords=64gb+ddr4&qid=1577747741&sr=8-8
https://linustechtips.com/topic/1140155-please-help/#findComment-13173323
