5 minutes ago, Khalma said:
So I'm getting the Corsair Carbide 275R as the case for my build. However, I was looking at it's specs and it says that the maximum GPU length is 270mm and my Asus Strix GTX 1080 is 298mm. Will it still fit or will I have to get another case?
Are you sure the maximum GPU length isn't 370mm? At least that's what my sources say...
Update, check corsairs specifications:
https://www.corsair.com/us/en/Categories/Products/Cases/Carbide-Series-275R-Tempered-Glass-Mid-Tower-Gaming-Case/p/CC-9011132-WW#tab-tech-specs
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
https://linustechtips.com/topic/1139925-will-it-fit/#findComment-13171521
you answered your question
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
https://linustechtips.com/topic/1139925-will-it-fit/#findComment-13171522
Just now, Khalma said:
Maybe my online retailer is wrong. I'll check other websites.
My System:
https://linustechtips.com/topic/1139925-will-it-fit/#findComment-13171530
