Hi, so basically I bought a RX 590 Fatboy to replace my RX 460. I took out the 460 and put in the 590 correctly (I think, I followed the video). I plug everything into my PC and turn it on, it turns on, all the lights and fans come on, my seagate harddrive light comes on, but my PC wont communicate with my monitor, I have tried different hdmi cables, took out my ram and put it back in (while pc was off), and cleaned out dust.
I have an Intel core I5-6500 processor, an Asus B150 Pro Gaming/AURA, 8gb of ram, RX 590 Fatboy, and EVEA 500W power supply, a seagate 4tb external harddrive, and a viewsonic curved 144hz monitor.
https://linustechtips.com/topic/1139356-pc-wont-work/
Maybe could be a chance the GPU is not fully seated into the PCI-e slot? have you tried uninstalling and reinstalling the card?
CPU: Ryzen 7 5800X GPU: Sapphire Pulse RX 9070XT Motherboard: Asus ROG Strix X470-F RAM: Corsair 32GB Vengeance 3600Mhz PSU: Corsair RM850X White
Cooling: Corsair H115i RGB Storage: Samsung 970 Evo NVME (2TB) Case: NZXT H500i White
Keyboard: Corsair K70 Mechanical Mouse: Logitech Superlight 2
https://linustechtips.com/topic/1139356-pc-wont-work/#findComment-13167408
Put the original GPU back in and see if it posts then.
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
https://linustechtips.com/topic/1139356-pc-wont-work/#findComment-13167418
If the processor you are using has on board graphics, you could plug your display cable to the available port on the motherboard, and see if it POSTs. If you are using a processor without on board graphics, you need a GPU. So I again would do these 2 things first:
1. Uninstall the GPU and plug it back in, retest.
2. Try reinstalling your old GPU and retest.
and of course, ensure all cables including display cables are fully seated, monitor is plugged in etc.
If you plug your old card in and it works, I would suspect the GPU has an issue. the only way to confirm after this would be to try the new card in a different system if possible.
https://linustechtips.com/topic/1139356-pc-wont-work/#findComment-13167470
Yeah something smells fishy here. I would still complete your attempt at re-seating the GPU and attempting to boot up, and follow that with your old card. I hope you bought the card new, because you can at least exchange it if it is defective. Otherwise, if you bought it used, I would be worried.
https://linustechtips.com/topic/1139356-pc-wont-work/#findComment-13167550
29 minutes ago, BlastRulez999 said:
But even without the new gpu, The pc should still display onto the monitor right?
Without the GPU the PC would display on a monitor connected to the motherboard if the CPU has integrated graphics.
Once the GPU is in that will be disabled and the monitor must be plugged into the GPU.
F@H
GPD Win 2
https://linustechtips.com/topic/1139356-pc-wont-work/#findComment-13167553
So you just didn't plug your monitor into your GPU...
F@H
GPD Win 2
https://linustechtips.com/topic/1139356-pc-wont-work/#findComment-13167561
So I want to confirm that you had a display cable plugged into your new GPU when the issue was present. I know thats probably a stupid question but no harm in asking.
If I had to make a guess, if you have it working with no GPU, if you install your old GPU into the system it will also probably work.
My last suggestion would be to try installing the new card into a different PCI-e port if possible. If you still have no display, I would guess you have a bad card. Return or exchange if possible.
https://linustechtips.com/topic/1139356-pc-wont-work/#findComment-13167585
Okay this could now move from a GPU issue to a motherboard issue. Try installing the new card into a different PCI express slot.
https://linustechtips.com/topic/1139356-pc-wont-work/#findComment-13167600
You still didn't answer the question.
F@H
GPD Win 2
https://linustechtips.com/topic/1139356-pc-wont-work/#findComment-13167601
Judging by his previous responses, I am assuming he had a display cable plugged into the GPU, as he mentions he did plug it into the motherboard (Assuming he had one plugged inn, in the first place)
https://linustechtips.com/topic/1139356-pc-wont-work/#findComment-13167609
for the sake of trial and error, I would still recommend trying a nother pci-e slot. if that means you have to unscrew the PSU and set it out of the way to do it, then so be it. I would also carefully inspect the terminals on the GPU's to make sure they arent damaged. When you removed the old card, did you pull back on the securing tab of the pci-e slot? did you just rip it out? a GPU swap of this caliber should not be very complicated at all.
https://linustechtips.com/topic/1139356-pc-wont-work/#findComment-13167675
Just now, BlastRulez999 said:
Mind you, this is my first time even opening this computer, I know nothing about it, dont even know what a PSU is. I know, I should have probably dont more research, and I tried another PCi slot with my old smaller card, that didnt work either
PSU is your power supply. That big box at the bottom with all the wires. At this point, if you are not comfortable further diagnosing the problem, I would suggest you take it to your local computer technicians for diag.
https://linustechtips.com/topic/1139356-pc-wont-work/#findComment-13167701
