Hello all. I am currently running:
MSI MPG X570 GAMING EDGE WIFI (latest BIOs version)
Ryzen 5 3600x
2 x 8 GB Trident Z @ 3200 MHz
RTX 2070 S
I was trying to upgrade to 2 x 16 Trident Z NEO variant @ 3600 MHz CL16-19-19-39 and can't seem to get stable performance from stock/auto settings, no overclocking. I've tried XMP profile and also manually entering CL timings and 1.35V. Is there something I'm missing? I am thoroughly confused especially because Linus' gang does nothing but suggest 3600 MHz ram for the Ryzen 3K series. I've tried two different sets of RAM now and can't seem to pin point the issues. I thought the first set was maybe just a bad set but have realized otherwise. I have found no actual help through my research of the interwebs.
The noticeable things that are happening when I boot into Windows is my audio is crackling horribly. I tried setting the audio quality to the lowest setting possible through Windows and no results. The last thing that happens is my PC going dark and rebooting it self after being in Windows for no more than 10 minutes at a time.
Something is obviously wrong, perhaps in the BIOs, but I set the corresponding CL timings, recommended DRAM voltage, and Infinity Fabric clock rate 1:1. When I revert back to my original ram everything is fine and well. I am not super experienced with anything in BIOs but I understand some of the more basic stuff. The only thing I could possibly think of is my HDD being 7 or 8 years old and having a hard time keeping up?
I really appreciate anyone taking the time to read this and perhaps something is more apparent to someone other than me!
THANK YOU
https://linustechtips.com/topic/1139265-ram-incompatible-please-help/
Hello and welcome.
Which RAM slots did you install into?
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
I am assuming you bought  2 x 16gb?  Or 4 x 8 gb?
What you can try booting with only one stick at a time and see if there is just a bad stick.  Run through your BIOS like you already did, but with only one stick installed.
CPU:   Ryzen 7  5800x      CPU Cooler: Corsair H115i Pro       Motherboard:  Asus x570 TUF Plus      Memory:  64GB Corsair Vengeance DDR4-3600
GPU:  ASUS TUF RTX3080        SSD: Crucial P5 1TB  PCIe NVMe  Samsung 990 Pro 2TB           PSU: Corsair CX750       Case: Thermaltake View 71 TG RGB
Monitors: LG 34" Ultrawide    Samsung 28" 4k
Set them at 3066MHz, try XPM on or off.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
2 x 16. Should I still try this although I detect 32 GBs working?
1 minute ago, chartmypants said:
Will this be to determine if they are even working properly? I don't understand running at lower speed than advertised. Thank you!!
This is the never ending story of AMD and RAM comparability
Yes.
