Grounding before building
Solved by ARikozuM,
4 minutes ago, Hassan170 said:so any piece of metal? like a doorknob. a coin? and what about using the psu?
Most people tend to touch their case or PSU. You can plug the PSU into the wall for extra security; make sure the switch is set to OFF or O.
1
voltigeurramon ·
Posted in Troubleshooting1 -
1
Vibora ·
Posted in New Builds and Planning5 -
5
3
Doctah ·
Posted in Peripherals3 -
8
