Graphics card overheating
Go to solution Solved by Crunchy Dragon,
5 minutes ago, Statik said:
I’ve never heard of windows doing that. Is it a pop up or what? And I assure you 70C won’t damage it. Max safe temp for my 2080 super is I believe 88C. Maybe 83
My overclocked GTX 780 regularly ran at 70C, still works fine to this day.
The lack of details is brutal.
Gaming Build:
CPU: Ryzen 7 3800x   |  GPU: Asus ROG STRIX 2080 SUPER Advanced (2115Mhz Core | 9251Mhz Memory) |  Motherboard: Asus X570 TUF GAMING-PLUS  |  RAM: G.Skill Ripjaws DDR4 3600MHz 16GB  |  PSU: Corsair RM850x  |  Storage: 1TB ADATA XPG SX8200 Pro, 250GB Samsung 840 Evo, 500GB Samsung 840 Evo  |  Cooler: Corsair H115i Pro XT  |  Case: Lian Li PC-O11
Peripherals:
Monitor: LG 34GK950F  |  Sound: Sennheiser HD 598  |  Mic: Blue Yeti  |  Keyboard: Corsair K95 RGB Platinum  |  Mouse: Logitech G502
Laptop:
Asus ROG Zephryus G15
Ryzen 7 4800HS, GTX1660Ti, 16GB DDR4 3200Mhz, 512GB nVME, 144hz
NAS:
QNAP TS-451
6TB Ironwolf Pro
70 degrees isn't overheating, 90 is
Primary PC:
PSU tier list
How many watts do I need?
1 minute ago, Binus Bech Bips000000000 said:
Gtx 1070 founders edition, no custom fans, havent overclocked it
What kind of case, how old is it, what’s the airflow situation, etc
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
2 minutes ago, Binus Bech Bips000000000 said:
Windows showed a notification saying that having it at 70 for a prolonged time could damage its lifespan
anything under 83 is fine, 70 is cool.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
Just now, Binus Bech Bips000000000 said:
But won't having it at 70 damage it?
No
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
no idea, but 99% of gpus will run over 70C during gaming loads.
3 minutes ago, Binus Bech Bips000000000 said:
This might be kind of a dumbass question but why would windows say that it'll get damaged? Maybe to prevent lawsuits?
Gaming Build:
Peripherals:
Laptop:
NAS:
QNAP TS-451
6TB Ironwolf Pro
Windows is drunk and don’t have a clue what he’s talking about...
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
Wait, what do you mean?
Who? Remember to tag or quote ppl otherwise they may not see you talking to them
                                          WHIRO
@Whiro I checked my notifications again and it turns out it was this temperature monitoring software called "CAM" that was giving the notifications about the temp. I honestly have no idea what to believe about the temp because of the notifications. Heres a photo of the notification
82c is slightly more worrying than 70c like you mentioned before. Just to be sure download HWinfo and check temps over there, I’m not fully trusting cam software
                                          WHIRO
Just download HWinfo. Where do I check the temps?
When you starting tick sensor only box and it’ll show your temps
                                          WHIRO
