yes the only thing to check is if your pc is ddr3 or dd4. speed is sort of a second but almost all ddr3 and ddr4 ram default to the slowest speed when first installed so it should not be as much of a compatibility issue there.
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
https://linustechtips.com/topic/1138412-upgrade-help/#findComment-13160145
Ty so much
https://linustechtips.com/topic/1138412-upgrade-help/#findComment-13160511
